Issue with CMake
Posted: Thu May 20, 2021 12:04 pm
by jbierlaire
I have installed CC on the Cloudcompare.org website, and it works perfectly fine.
I know want to develop a CC plugin. For me to try out and visualize small changes in the source code I am writing, I need to add my plugin folder in the CC plugin directory.
However, with the version installed from cloudcompare.org, the plugin directory only has .dll files, and I can't copy my folder in this directory, in order to try out my plugin (as explained in https://github.com/CloudCompare/CloudCo ... IBUTING.md). I also can add that qDummyPlugin does not exist anymore (as you surely know).
So I have tried to install the version from github, using the following link instructions https://github.com/CloudCompare/CloudCo ... r/BUILD.md After cloning the directory, I have everything I need to compile CC using CMake.
Here are my directories : source code : C:/Users/bierlaire/Desktop/CloudCompare with everything that I just cloned
where to build the binaries : C:/Users/bierlaire/Desktop/build (empty folder)
Please note that I can't work on C:/Program Files since I have not all the permissions on my laptop.
Trying to compile, I get this error :
CMake Error at CMakeLists.txt:3 (project):
  Generator
    Visual Studio 15 2017
  could not find any instance of Visual Studio.
Configuring incomplete, errors occurred!
See also "C:/Users/bierlaire/Desktop/build/CMakeFiles/CMakeOutput.log".
I have everything in the prerequisites, as well as Visual Studio 2019 and Visual Studio 2017. This is also why this issue is frustrating.
Please be aware that I am a beginner with CMake.
I am also open to any other solution in order to try out my plugin code without using CMake.
Any help would be greatly appreciated,
Jules
Re: Issue with CMake
Posted: Fri May 21, 2021 12:40 am
by WargodHernandez
I would suggest using visual studio 2019 CMAKE, just right click on the folder C:/Users/bierlaire/Desktop/CloudCompare and select "Open with Visual Studio".
then set your CMAKE settings from the project menu
Posted: Fri May 21, 2021 4:52 am
by jbierlaire
Thank you for your answer.
I have done what you suggested, and I had an issue with QT5, which I fixed by adding the correct folder path.
Now trying to right click and open the folder, I get this issue :
I have tried to look at CMakeLists.txt, but I have no clue on what should fix this error.
Do you have any idea ?
Posted: Fri May 21, 2021 3:17 pm
by WargodHernandez
To give me a better idea of how you have it set up, please attach the CMakeSettings.json file that VS2019 created.
go to the CMake Settings like before and then select CMakeSettings.json
Posted: Tue May 25, 2021 4:25 am
by jbierlaire
Here is my CMakeSettings.json :
  "configurations": [
      "name": "x64-Debug",
      "generator": "Ninja",
      "configurationType": "Debug",
      "inheritEnvironments": [ "msvc_x64_x64" ],
      "buildRoot": "C:/Users/bierlaire/Desktop/build/CMakeFiles",
      "installRoot": "${projectDir}\\out\\install\\${name}",
      "cmakeCommandArgs": "",
      "buildCommandArgs": "",
      "ctestCommandArgs": "",
      "cmakeToolchain": "C:/Users/bierlaire/Desktop/CloudCompare/CMakeLists.txt"
Posted: Tue May 25, 2021 2:52 pm
by WargodHernandez
I would remove this line
The CloudCompare CMakeLists is not a tool chain.
