How to calculate 3D objects’ volume?
Posted: Mon Sep 20, 2021 6:08 am
by JamesGregory
Hello to all! Would someone tell me how i can calculate the volume of 3D objects plz? Thanks a lot.
Re: How to calculate 3D objects’ volume?
Posted: Tue Sep 21, 2021 6:33 pm
really 3D or 2.5D?
Anyway, there are basically two options that may work for you:
- https://www.cloudcompare.org/doc/wiki/i ... ure_volume
- https://www.cloudcompare.org/doc/wiki/i ... .5D_Volume
Posted: Thu Sep 23, 2021 10:13 am
by DA523
Sorry I deleted this post by mistake ...while posting a new one
how to recover it
Posted: Sat Oct 02, 2021 4:01 pm
by DA523
Lets speak about 2.5D volume (Tools >> VOLUME >>Compute 2.5D volume)
it is the most professional method to find volume between 2 points clouds and works fine on 2 points clouds or single cloud and plane (constant x,y, or z)
it is the same as finding the area under function curve by numerical integration
Care should be taken because , it can give bad volume in some situations because of :
- Convex hull area if interpolation is used
- Empty cells, if the less dense points cloud is used with leave it empty choice
- Big grid size (too many points fail in each cell)
- One points cloud has more than one layer in the same projection direction
For example, 2.5D volume can not work on this attached mesh
Attached 1 bin file
2.5D volume.zip
(2.14 KiB) Downloaded 1531 times
Posted: Thu Aug 28, 2025 7:54 am
by geotyr
so I needed to compute a 3d volume for a surface that is not fit to the 2.5 volume computation (more than 1 points with the same x and y coordinates and different Z)
what I did is subsample the cloud points
compute normals
and then compute poisson reconstruction with the drichlet algorithm
this creates a closed volume
inverting the normals allows closing the surface in one direction or the other
it does not work for precise calculations but helps with general idea
depending on how normals are calculated affects how the surface is closed
Posted: Thu Aug 28, 2025 10:11 pm
by DA523
Be careful about mesh volume you may have non-manifold and normal problem
you have to cross check using meshlab and blender to double check CC volume
