-O command suggestion
I would suggest adding something like -IGNORE_SF in the -O command to avoid loading when not needed, so that when the SF are not needed like when meshing.
Re: -O command suggestion
Ah, sadly no I/O filter but the LAS filter has this option to ignore SFs.
But you have the -REMOVE_ALL_SFS option to remove them just after loading the entities.
true! thanks for the tip I used it and I can get rid of bloat easily! I love command line so much, is multiplies my capacity of work by infinite.
