Detect overhang on a cliff into a pointcloud
Posted: Wed Jun 01, 2022 7:58 am
by astephan
Hi !
Is there a way to detect and isolate hangovers in a point cloud ?
It would be usefull to isolate them before running a rasterize process.
Thank you.
Re: Detect overhang on a cliff into a pointcloud
Posted: Thu Jun 09, 2022 10:07 am
Sadly, apart from the Rasterize tool itself, I don't see any way to do that currently in CloudCompare... But maybe other users have some ideas?
Posted: Mon Jun 13, 2022 2:37 pm
by astephan
Thank you Daniel,
And what about calculate normals and isolate the points with normals under 0° (horizon) ?
Posted: Mon Jun 13, 2022 9:26 pm
by DA523
Check this attached simple example using normal filtering
I think it does not work if the cliff has multiple hangover layers ??
Group5.zip
(1.84 MiB) Downloaded 1496 times
Group3.zip
(813.51 KiB) Downloaded 1535 times
Posted: Tue Jun 14, 2022 8:51 pm
Another way is to use the 'Hidden Point Removal' plugin (look at the cloud from the side where you see the points you want to keep).
Posted: Tue Jun 21, 2022 7:25 pm
by astephan
Thank you Daniel,
It works with a simple overhang and multiples too but with multiples, i have to isolate afterwards the 'second', 'third'... layers if i want to generate the contours. Not possible to just rasterise because of the overlays on the point cloud.
I will try to make the 2 operations : classify with normals <0 and use hidden point removal.
Thank you.
Posted: Thu Feb 16, 2023 4:58 pm
by Ana
Hi everyone,
Stephan, could you find a way to detect multiple overhangs on a cliff at the end? I read you were planning to use normals<0 and Hidden point removal. Did it work? Could you share a descriptive workflow? (screenshots or a short video would be enormously appreciated)
Daniel, if you developed a procedure to calculate overhangs on vertical walls, it would be helpful if you let me know.
Thank you
Ana
Posted: Sat Feb 18, 2023 9:12 am
I didn't develop any specific procedure. I was just thinking that the Rasterize tool, with its ability to extract the lowest or the highest points inside a raster cell, could maybe be used to detect the overhanging points. But it doesn't look very robust...
