Primitive sphere changes its diminsions
DA523
Post by DA523 »
file --> Primitive Factory
sphere radius =6370000
no shift
When click on sphere shape or sub sample it , it changes its dimensions
Re: Primitive sphere changes its diminsions
Ah! That's probably because it exceeds the maximum value for the radius field in the GUI.
But clearly, 6370000 will exceed the accuracy limit of CloudCompare...
DA523
Post by DA523 »
If I do not click on sphere shape in project pane ,
I can still clone pc to new pc and it keeps real dimensions
Yes, as long as you don't display the properties the radius won't be 'capped'. I could change the GUI maximum acceptable number of course (but my point was that this is not very reasonable due to the inaccuracy caused by such large coordinates/values, and you may find this issue in other places).
