[SOLVED ]Label Connected Components, recall last value
PablerasBCN
Post by PablerasBCN »
A tiny request that would make life easyer. Whne I use the label tool to break sparse elements I would love that it did recall last value, since I may need to fine tune a bit because some small chunk may still be adhered to the main chunk. I may seem easy to recall but hwen you're doing like a crapton of operations it is not that easy and doubs come, specially if it takes a bit to break into parts.
Alternativelly, and may be even more funcional, you could add the values to the naming of the group that holds all the chunks, similarly as you rename the SF when using compute fatures that includes the radius (that is super convenient to compare ressults, I love it!)
Re: Label Connected Components, recall last value
Ah, this one was easy ;)
I've updated the latest 2.13.beta version.
PablerasBCN
Tested to work. Thank you Daniel, very convenient to move one value up-down based on ressults.
This tools works very nice to cutout the clutter that needs to go to another class than the main cloud chunk.
