Tunnel volume calculations
Qrack
Post by Qrack »
Hey,
I have to calculate the volume between tunnel base wall structure and finished casing, i have both scans before and after cementing. Is it possible to do this in cloud compare?
Best regards
Re: Tunnel volume calculations
Hum, I guess it's 3D clouds then, so there's no obvious way to do it in CloudCompare... You can compute distances, but then there's no robust way to convert them to volume.
DA523
Post by DA523 »
If your 2 scans are dense, I believe that there is a software or an algorithm to find volume
