ICP , data scalar field as weight
Delmer
Post by Delmer »
Regarding the advanced ICP parameters "Use displayed model/data scalar field as weights" and "Enable farthest point removal", are the formulas of these documented (or available) anywhere?
https://www.cloudcompare.org/doc/wiki/i ... ?title=ICP
So far I've only found a reference to the ICP algorithm used (viewtopic.php?t=4967) but there is no mention of weights in the paper.
Re: ICP , data scalar field as weight
Ah probably not... you would have to look at the code.
