3D reconstruction
Posted: Mon Jun 24, 2024 1:14 pm
by Andresilva0409
Hey guys,
Guys, I have this point cloud (see image 1) with these holes and I want to create a mesh of it.
So when I create a mesh, cloudcompare fills these holes automatically(see image 2) and I don't want that, and I wanted to know if anyone here knows how to solve this problem.
Thank you.
Re: 3D reconstruction
Posted: Mon Jun 24, 2024 3:34 pm
I guess you should activate the 'Density' output?
See
https://www.cloudcompare.org/doc/wiki/i ... n_(plugin), last section.
Posted: Tue Jun 25, 2024 7:14 am
by DA523
If you can not manage by using "Density' output", You can use segment tools to open a hole in the mesh.
Also, You can edit in Blender 3D software
Posted: Wed Jun 26, 2024 1:05 pm
by Gregnew
Andresilva0409 wrote: Mon Jun 24, 2024 1:14 pm
Hey guys,
Thank you.
To prevent CloudCompare from filling holes automatically when creating a mesh from a point cloud, you typically need to adjust the parameters or settings in the mesh generation process
Posted: Wed Jun 26, 2024 9:18 pm
by DA523
In many cases, adjusting the parameters or settings in the mesh generation process does not help
for example, can we generate a mesh with a side hole in the attached pc example
Posted: Thu Jun 27, 2024 9:13 am
by DA523
Gregnew wrote: Wed Jun 26, 2024 1:05 pm
I attached here pointscloud example with a small hole in its top, I can not adjust the parameters to generate a real shape mesh with a small hole in the top.
Any idea just to investigate the PoissonRecon limit
- Screenshot (323).png (152.46 KiB) Viewed 9080 times
Posted: Sun Jun 30, 2024 8:46 am
Yes, PoissonRecon density is based on the proximity between the original points and the reconstructed nodes...
That's a bit clunky, but you could maybe sample points on the total reconstructed mesh. Then segment the hole part (point cloud subest) and add it to your original cloud. And re-mesh again!
