2.14 beta can't read .glb file.
Posted: Fri Feb 20, 2026 4:07 am
by Jay_Ki
after 2.14 beta update,
CC can't read .glb file.
Please handle this issue. Thanks a lot.
Re: 2.14 beta can't read .glb file.
Posted: Sat Feb 21, 2026 10:20 am
Yes, this format is not supported by CloudCompare. That's not an 'issue' per se ;)
Posted: Sat Feb 21, 2026 5:25 pm
by Jay_Ki
But previous version can open .glb file.
Posted: Sat Feb 21, 2026 10:02 pm
Ah, it must have been managed by the Mesh I/O plugin then. This plugin was not compiling with Qt 6 anymore, but I managed to fix it I think (I haven't been able to test).
Posted: Sat Feb 21, 2026 11:01 pm
Can you test this new version:
(sadly it's not signed with a certificate, so you may have to convince Windows that it's safe to run)
Posted: Mon Feb 23, 2026 1:23 am
by Jay_Ki
It works. Thanks a lot. :)
Posted: Thu Sep 03, 2026 1:22 pm
by JSNM
Ran into the same thing on 2.14. Until GLB support is back, the workaround that costs the least effort: convert the GLB to OBJ first and open that instead.
furnimesh.com/convert/glb-to-obj does it in the browser, no install, and the scale came through correctly for me, so measurements in CloudCompare stay trustworthy. PLY via a converter also works if you need vertex colors, but for a textured mesh the OBJ route was the cleaner import.
