Opening a file in CC from AutoCad
Posted: Mon Aug 03, 2026 8:43 am
by westergu
I have made a small script in Autocad that let you choose a line, saves it as an OBJ file and then opens it in Cloudcompare. The problem is that it always opens a new Cloudcompare session. So my question is, if there is a command line argument that opens the OBJ-file in an existing (or most recently opened) Cloudcompare window?
Hopefully somebody knows a walkaround to this problem :-).
Re: Opening a file in CC from AutoCad
Posted: Thu Aug 06, 2026 3:45 pm
A solution might be to use the JSon RPC plugin: https://github.com/CloudCompare/qJSonRPCPlugin
(but I don't know how it works, as I've personally never used it).
Posted: Mon Aug 10, 2026 9:08 am
by westergu
Thank you for the suggestion, but it seems this is a bit overkill for my skills :-)
