qCC_db version 2.13.alpha (Qt) - 31 May 2022
CloudCompare 3D entities
This is the complete list of members for ccRasterGrid, including all inherited members.
| ccRasterGrid() | ccRasterGrid | |
| clear() | ccRasterGrid | |
| computeCellCenter(int i, int j, unsigned char dimX, unsigned char dimY) const | ccRasterGrid | inline |
| computeCellPos(const CCVector3 &P, unsigned char dimX, unsigned char dimY) const | ccRasterGrid | inline |
| ComputeGridSize(unsigned char Z, const ccBBox &box, double gridStep, unsigned &width, unsigned &height) | ccRasterGrid | static |
| convertToCloud(const std::vector< ExportableFields > &exportedFields, bool interpolateSF, bool interpolateColors, bool resampleInputCloudXY, bool resampleInputCloudZ, ccGenericPointCloud *inputCloud, unsigned char Z, const ccBBox &box, bool fillEmptyCells, double emptyCellsHeight, bool exportToOriginalCS) const | ccRasterGrid | |
| EmptyCellFillOption enum name | ccRasterGrid | |
| ExportableFields enum name | ccRasterGrid | |
| FILL_AVERAGE_HEIGHT enum value (defined in ccRasterGrid) | ccRasterGrid | |
| FILL_CUSTOM_HEIGHT enum value (defined in ccRasterGrid) | ccRasterGrid | |
| FILL_MAXIMUM_HEIGHT enum value (defined in ccRasterGrid) | ccRasterGrid | |
| FILL_MINIMUM_HEIGHT enum value (defined in ccRasterGrid) | ccRasterGrid | |
| fillEmptyCells(EmptyCellFillOption fillEmptyCellsStrategy, double customCellHeight=0) | ccRasterGrid | |
| fillWith(ccGenericPointCloud *cloud, unsigned char projectionDimension, ProjectionType projectionType, bool doInterpolateEmptyCells, double maxEdgeLength, ProjectionType sfInterpolation=INVALID_PROJECTION_TYPE, ccProgressDialog *progressDialog=nullptr) | ccRasterGrid | |
| GetDefaultFieldName(ExportableFields field) | ccRasterGrid | static |
| gridStep | ccRasterGrid | |
| hasColors | ccRasterGrid | |
| height | ccRasterGrid | |
| init(unsigned w, unsigned h, double gridStep, const CCVector3d &minCorner) | ccRasterGrid | |
| INTERPOLATE enum value (defined in ccRasterGrid) | ccRasterGrid | |
| interpolateEmptyCells(double maxSquareEdgeLength) | ccRasterGrid | |
| INVALID_PROJECTION_TYPE enum value (defined in ccRasterGrid) | ccRasterGrid | |
| isValid() const | ccRasterGrid | inline |
| LEAVE_EMPTY enum value (defined in ccRasterGrid) | ccRasterGrid | |
| maxHeight | ccRasterGrid | |
| meanHeight | ccRasterGrid | |
| minCorner | ccRasterGrid | |
| minHeight | ccRasterGrid | |
| nonEmptyCellCount | ccRasterGrid | |
| PER_CELL_AVG_HEIGHT enum value (defined in ccRasterGrid) | ccRasterGrid | |
| PER_CELL_COUNT enum value (defined in ccRasterGrid) | ccRasterGrid | |
| PER_CELL_HEIGHT enum value (defined in ccRasterGrid) | ccRasterGrid | |
| PER_CELL_HEIGHT_RANGE enum value (defined in ccRasterGrid) | ccRasterGrid | |
| PER_CELL_HEIGHT_STD_DEV enum value (defined in ccRasterGrid) | ccRasterGrid | |
| PER_CELL_INVALID enum value (defined in ccRasterGrid) | ccRasterGrid | |
| PER_CELL_MAX_HEIGHT enum value (defined in ccRasterGrid) | ccRasterGrid | |
| PER_CELL_MEDIAN_HEIGHT enum value (defined in ccRasterGrid) | ccRasterGrid | |
| PER_CELL_MIN_HEIGHT enum value (defined in ccRasterGrid) | ccRasterGrid | |
| PROJ_AVERAGE_VALUE enum value (defined in ccRasterGrid) | ccRasterGrid | |
| PROJ_MAXIMUM_VALUE enum value (defined in ccRasterGrid) | ccRasterGrid | |
| PROJ_MEDIAN_VALUE enum value (defined in ccRasterGrid) | ccRasterGrid | |
| PROJ_MINIMUM_VALUE enum value (defined in ccRasterGrid) | ccRasterGrid | |
| ProjectionType enum name | ccRasterGrid | |
| reset() | ccRasterGrid | |
| Row typedef | ccRasterGrid | |
| rows | ccRasterGrid | |
| scalarFields | ccRasterGrid | |
| setValid(bool state) | ccRasterGrid | inline |
| SF typedef | ccRasterGrid | |
| updateCellStats() | ccRasterGrid | |
| updateNonEmptyCellCount() | ccRasterGrid | |
| valid | ccRasterGrid | |
| validCellCount | ccRasterGrid | |
| width | ccRasterGrid | |
| ~ccRasterGrid() | ccRasterGrid | virtual |
