qCC_io version 2.13.alpha (Qt) - 31 May 2022
CloudCompare standard I/O filters (file readers & writers)
This is the complete list of members for AsciiOpenDlg, including all inherited members.
| apply() (defined in AsciiOpenDlg) | AsciiOpenDlg | protected |
| applyAll() (defined in AsciiOpenDlg) | AsciiOpenDlg | protected |
| AsciiOpenDlg(QWidget *parent=nullptr) | AsciiOpenDlg | explicit |
| autoFindBestSeparator() | AsciiOpenDlg | protected |
| CheckOpenSequence(const Sequence &sequence, QString &errorMessage) | AsciiOpenDlg | static |
| checkSelectedColumnsValidity() (defined in AsciiOpenDlg) | AsciiOpenDlg | protected |
| columnsTypeHasChanged(int index) (defined in AsciiOpenDlg) | AsciiOpenDlg | protected |
| ColumnType enum name (defined in AsciiOpenDlg) | AsciiOpenDlg | protected |
| commaDecimalCheckBoxToggled(bool) | AsciiOpenDlg | |
| getAverageLineSize() const | AsciiOpenDlg | inline |
| getColumnsCount() const | AsciiOpenDlg | inline |
| getMaxCloudSize() const | AsciiOpenDlg | |
| getOpenSequence() const | AsciiOpenDlg | |
| getSeparator() const | AsciiOpenDlg | inline |
| getSkippedLinesCount() const | AsciiOpenDlg | inline |
| IGNORED enum value (defined in AsciiOpenDlg) | AsciiOpenDlg | protected |
| m_averageLineSize (defined in AsciiOpenDlg) | AsciiOpenDlg | protected |
| m_columnsCount (defined in AsciiOpenDlg) | AsciiOpenDlg | protected |
| m_columnType | AsciiOpenDlg | protected |
| m_filename (defined in AsciiOpenDlg) | AsciiOpenDlg | protected |
| m_headerLine (defined in AsciiOpenDlg) | AsciiOpenDlg | protected |
| m_separator (defined in AsciiOpenDlg) | AsciiOpenDlg | protected |
| m_skippedLines (defined in AsciiOpenDlg) | AsciiOpenDlg | protected |
| m_stream (defined in AsciiOpenDlg) | AsciiOpenDlg | protected |
| m_ui (defined in AsciiOpenDlg) | AsciiOpenDlg | protected |
| onSeparatorChange(const QString &separator) | AsciiOpenDlg | |
| ResetApplyAll() | AsciiOpenDlg | static |
| restorePreviousContext() | AsciiOpenDlg | |
| safeSequence() const | AsciiOpenDlg | |
| Sequence typedef | AsciiOpenDlg | |
| setInput(const QString &filename, QTextStream *stream=nullptr) | AsciiOpenDlg | |
| setSeparator(QChar) | AsciiOpenDlg | protected |
| setSkippedLines(int linesCount) | AsciiOpenDlg | |
| shortcutButtonPressed() (defined in AsciiOpenDlg) | AsciiOpenDlg | protected |
| showLabelsIn2D() const | AsciiOpenDlg | |
| TEXT enum value (defined in AsciiOpenDlg) | AsciiOpenDlg | protected |
| UNKNOWN enum value (defined in AsciiOpenDlg) | AsciiOpenDlg | protected |
| updateTable() | AsciiOpenDlg | |
| useCommaAsDecimal() const | AsciiOpenDlg | |
| VALID enum value (defined in AsciiOpenDlg) | AsciiOpenDlg | protected |
| ~AsciiOpenDlg() override | AsciiOpenDlg |
