qCC_io version 2.13.alpha (Qt) - 31 May 2022
CloudCompare standard I/O filters (file readers & writers)
This is the complete list of members for ImageFileFilter, including all inherited members.
| BuiltIn enum value (defined in FileIOFilter) | FileIOFilter | |
| canSave(CC_CLASS_ENUM type, bool &multiple, bool &exclusive) const override | ImageFileFilter | virtual |
| CheckForSpecialChars(const QString &filename) | FileIOFilter | static |
| DEFAULT_PRIORITY (defined in FileIOFilter) | FileIOFilter | protectedstatic |
| DisplayErrorMessage(CC_FILE_ERROR err, const QString &action, const QString &filename) | FileIOFilter | static |
| DynamicInfo enum value (defined in FileIOFilter) | FileIOFilter | |
| Export enum value (defined in FileIOFilter) | FileIOFilter | |
| exportSupported() const | FileIOFilter | |
| FileIOFilter(const FilterInfo &info) (defined in FileIOFilter) | FileIOFilter | explicitprotected |
| FilterContainer typedef | FileIOFilter | |
| FilterFeature enum name (defined in FileIOFilter) | FileIOFilter | |
| FindBestFilterForExtension(const QString &ext) | FileIOFilter | static |
| getDefaultExtension() const | FileIOFilter | |
| getFileFilters(bool onImport) const | FileIOFilter | |
| GetFilter(const QString &fileFilter, bool onImport) | FileIOFilter | static |
| GetFilters() | FileIOFilter | static |
| GetLoadFilename(const QString &dialogTitle, const QString &imageLoadPath, QWidget *parentWidget=nullptr) | ImageFileFilter | static |
| GetSaveFilename(const QString &dialogTitle, const QString &baseName, const QString &imageSavePath, QWidget *parentWidget=nullptr) | ImageFileFilter | static |
| HandleGlobalShift(const CCVector3d &P, CCVector3d &Pshift, bool &preserveCoordinateShift, LoadParameters &loadParameters, bool useInputCoordinatesShiftIfPossible=false) | FileIOFilter | static |
| ImageFileFilter() (defined in ImageFileFilter) | ImageFileFilter | |
| Import enum value (defined in FileIOFilter) | FileIOFilter | |
| ImportFilterList() | FileIOFilter | static |
| importSupported() const | FileIOFilter | |
| IncreaseSesionCounter() | FileIOFilter | static |
| InitInternalFilters() | FileIOFilter | static |
| loadFile(const QString &filename, ccHObject &container, LoadParameters ¶meters) override | ImageFileFilter | virtual |
| LoadFromFile(const QString &filename, LoadParameters ¶meters, Shared filter, CC_FILE_ERROR &result) | FileIOFilter | static |
| LoadFromFile(const QString &filename, LoadParameters ¶meters, CC_FILE_ERROR &result, const QString &fileFilter=QString()) | FileIOFilter | static |
| NoFeatures enum value (defined in FileIOFilter) | FileIOFilter | |
| Register(Shared filter) | FileIOFilter | static |
| ResetSesionCounter() | FileIOFilter | static |
| saveToFile(ccHObject *entity, const QString &filename, const SaveParameters ¶meters) override | ImageFileFilter | virtual |
| SaveToFile(ccHObject *entities, const QString &filename, const SaveParameters ¶meters, Shared filter) | FileIOFilter | static |
| SaveToFile(ccHObject *entities, const QString &filename, const SaveParameters ¶meters, const QString &fileFilter) | FileIOFilter | static |
| setExportFileFilterStrings(const QStringList &filterStrings) | FileIOFilter | protected |
| setImportExtensions(const QStringList &extensions) | FileIOFilter | protected |
| setImportFileFilterStrings(const QStringList &filterStrings) | FileIOFilter | protected |
| Shared typedef | FileIOFilter | |
| unregister() | FileIOFilter | inlinevirtual |
| UnregisterAll() | FileIOFilter | static |
| ~FileIOFilter()=default (defined in FileIOFilter) | FileIOFilter | virtual |
