Scalar fields\Convert to RGB
Revision as of 10:16, 9 February 2015 by Daniel (talk | contribs)
This tool is accessible via the 'Edit > Scalar fields > Convert to RGB' menu.
Simply converts the active scalar field to a RGB color field.
The colors assigned to the points are exactly the ones visible on the screen at the time the method is called. Therefore the rendering won't change. However, CloudCompare will automatically hide the scalar field and activate the RGB field instead.
Note: the original scalar field is not modified nor deleted.
