Fit Sphere
Revision as of 21:09, 12 February 2015 by Daniel (talk | contribs) (Created page with "= Menu = This tool is accessible via the 'Tools > Fit > Sphere' menu. = Description = This tool fits a sphere on a cloud. = Procedure = Select one or several point clouds...")
CloudCompare will fit a sphere primitive on each cloud (the radius will be detected automatically).
Fitted sphere
  • center (can also be found as the center of the sphere bounding-box in the sphere entity properties)
  • radius (can also be found in the sphere entity properties)
  • sphere fitting RMS (is recalled in the default sphere entity name)
Note: theoretically the sphere fitting algorithm can handle up to 50% outliers.
