Lock rotation about vert. axis
Revision as of 15:31, 13 February 2015 by Daniel (talk | contribs) (Created page with "= Menu = This method is accessible via the 'Display > Lock rotation about vert. axis' menu. Alternatively you can use the ''L'' shortcut. = Description = This method simpl...")
Alternatively you can use the L shortcut.
This method simply locks the camera rotation around the vertical (Z) axis (in the active 3D view).
When activated a '[ROTATION LOCKED]' message will appear in the top part of the 3D view:
Simply call this method again (or use the L shortcut) to disable this mode.
