Global Shift and Scale
Revision as of 20:30, 17 February 2015 by Daniel (talk | contribs) (→Mathematics)
But why?
Mathematics
Plocal = (Pglobal + T) * S
or equivalently:
Pglobal = Plocal / S - T
Properties
Edition
Bookmarks
