Edit\Subsample
Revision as of 22:07, 17 February 2015 by Daniel (talk | contribs) (→Description)
This tool is accessible via the 'Edit > Subsample' menu, or via the icon in the upper main toolbar.
Several subsampling methods are available:
  • random
  • spatial
  • octree-based
  • for each input cloud, a new subsampled cloud is created (the original one is simply deactivated)
  • a subsampled cloud is a subset of the input cloud (the original points are not displaced)
  • thanks to this, a subsampled cloud keeps the features of its source cloud (scalar fields, colors, normals, etc.)
Subsampling dialog
Random
Subsampling 'Random' parameters
Spatial
Use active SF (option)
Original cloud with a scalar field proportional to the local curvature
Subsampling 'Spatial' parameters based on the active scalar field values
Subsampling output
Octree
  • the higher the level is, the smaller the cells are (so the more points you'll keep)
  • the maximum octree level is 10 in the 32 bits version of CloudCompare, and 21 in the 64 bits version.
  • the tool differs from the 'Octree > Resample' method. The Resample tool computes the center of gravity of the points falling in each cell (i.e. the created cloud is not a subset of the original cloud)
