Mesh\Convert texture/material to RGB
Revision as of 09:04, 20 February 2015 by Daniel (talk | contribs) (→Description)
This tool is accessible via the 'Edit > Mesh > Convert texture/material to RGB' menu.
Converts the mesh material and/or texture information of the selected mesh to a per-vertex RGB field.
For each vertex of the mesh, this method will interpolate the nearest texture color or take the triangle's associated material color if no texture is available.
Warning: if the vertices are sparse, the visual rendering of the output RGB field might be quite different than the original one.
