Fit Quadric
Revision as of 14:23, 20 February 2015 by Daniel (talk | contribs) (→Procedure)
This tool is accessible via the 'Tools > Fit > 2.5D Quadric' menu.
This tool fits a 2.5D quadric on a point cloud.
For each cloud CloudCompare will fit a 2.5D Quadric (the cloud is first projected on its best fit plane).
Fitted quadric (+ distances between the original cloud and the fitted quadric)
  • the 6 quadric equation coefficients (a + b.x + c.y + d.x2 + e.y2 = 0)
  • the quadric fitting RMS
  • the fitted quadric is added to the DB tree as a child of the cloud
  • the quadric is represented as a standard triangular mesh. Therefore you can select both the cloud and the fitted quadric and compute the distance between them (with 'Tools > Distances > Cloud/Mesh Dist.')
