Density
Revision as of 14:27, 20 February 2015 by Daniel (talk | contribs) (→Output)
A dialog will appear:
Precise or Approximate
Output
The density output can be:
Density output example
Note: a point with no neighbor in the spherical neighborhood will have an invalid (NaN) density.
