CANUPO (plugin)
Revision as of 16:50, 20 February 2015 by Daniel (talk | contribs) (→Train a classifier)
  • the tutorial for the original command line tool
Getting a working classifier
Use an existing ".prm" file
Train your own classifier
Prepare the data
Train a classifier
Apply a classifier on a cloud
Acknowledgments
