Compilation
Revision as of 10:21, 26 August 2015 by Daniel (talk | contribs) (→[Optional] Setup for Cork + MPIR support (for qCork))
Compilation with CMake
Prerequisites
Generating the project
    2. qCork (see below)
    4. qEDL
    5. qHPR
    6. qKinect (see below)
    8. qPCV
    9. qPoissonRecon
    11. qSRA
    12. qSSAO
    1. On Visual C++ (Windows):
Not ready yet.
  • edit the dl_dxf.cpp file
  1. MPIR 2.6.0
Generate the project files
Compiling the project
Appendix
Common issues
        //#include <QElapsedTimer>
        #include <QTime>
        typedef QTime QElapsedTimer;
  2. to compile with Visual 2010 you must then apply the following patch: [1] (this solves a bug from the MSVC 2010 compiler that prevents Qt from running correctly in release mode)
    4. And follow this guide
