Display modes
Revision as of 21:14, 6 October 2015 by Daniel (talk | contribs) (→Stereo mode (anaglyph))
Main display modes
Orthographic view
Perspective view
Object-centered
Viewer-based
Bubble-view (polar)
Note: the B shortcut can be used to enter this method.
To activate it, simply click on the icon in the left '3D view' toolbar. The following dialog will appear:
Basically this dialog lets you choose the type of glasses (red/blue or red/cyan) and the eye separation ratio. Increasing this ratio will increase the stereo effect... but this can also cause an unnatural feeling and headaches ;). You can also choose to use a dynamic focal distance (so as to always focus on the current rotation center whatever the camera position) or a fixed focal distance (typically if you need to focus on a particular point in the scene - however moving around with a fixed focal might also be very strange and give you headaches ;).
Please note that:
  • the background is always forced to a plain black color in stereo mode
