Command line mode
Revision as of 10:05, 31 October 2015 by Daniel (talk | contribs) (→Available options (version 2.6.2 and higher))
{type} can be MEAN or GAUSS.
  • the updated cloud is automatically saved (see the AUTO_SAVE command to change this)
