Scalar fields\Arithmetic
Revision as of 11:46, 3 December 2015 by Daniel (talk | contribs)
This tool is accessible via the 'Edit > Scalar fields > Arithmetic' menu or the icon in the upper main toolbar.
This tool allows to:
  • perform standard arithmetic operations between two scalar fields of the same cloud (+,-,*,/)
  • or apply mathematical functions to a single scalar field
Edit > Scalar Fields > Arithmetic dialog
Other than the standard operations (that can be applied to a second scalar field or a constant value), the other supported mathematical functions are:
  • square root
  • power of 2
  • power of 3
  • EXP (exponential)
  • LOG (natural log)
  • LOG10 (base 10 log)
  • COS (radians)
  • SIN (radians)
  • TAN(radians)
  • ACOS
  • ASIN
  • ATAN
  • Integer part
  • Inverse (1/x)
Since version 2.6.3:
  • the user can select a constant value instead of a secondary scalar field for the standard operations (+,-,*,/)
  • the user can choose to update the first scalar field directly ('in place'). Otherwise a new scalar field will be created. Anyway the source scalar fields are never deleted.
