Animation (plugin)
Usage
Creating viewport objects
- for now the viewports must be created in the chronological order.
- viewport objects store almost all the display parameters (even the point size, etc.). When interpolating the frames between each viewport objects, CloudCompare will actually interpolate all those parameters.
- for more convenience, it is better to regularly sample the viewpoints (as the default duration of the output video between each viewpoint is the same - this can be changed for each step afterwards but this can be quite cumbersome if you have a lot of viewpoints).
Animation parameters
Output video parameters
- the frame rate (in frame per second (fps) - 24 or 25 fps should be the minimum)
- the bitrate (the higher, the better the video quality will be but the bigger the file - see Youtube recommendations for instance)
- and the output filename
Note that the video output format is automatically guessed from the extension (mpg, avi, etc.). The available output formats depend on the codecs installed on your machine.
To setup the bitrate, you can follow
Rendering
Saving the parameters
Tutorial
