Animation (plugin)
Revision as of 10:22, 22 April 2016 by Daniel (talk | contribs)
Usage
Creating viewport objects
Animation parameters
Output video parameters
  • the output filename
Previewing
Rendering
Saving the parameters
Tutorial
