Cross Section
Additionally, this tool can:
Editing the clipping box
Interactively
Numerically
Visualization
Extract a single slice
Extract a single contour
The user must set:
Additional options are:
button
- to extract a non-closed contour, see the Extract Sections tool.
To extract several slices or contours at once, click on the 'Extract multiple slices' icon (in the right 'Slices' frame).
Other parameters are:
- Repeat dimension: the extraction process can be repeated in one or multiple dimensions (by default only the 'flat' dimension will be checked)
Reset the clipping box
Close the tool
