Global Shift and Scale
Revision as of 11:54, 22 April 2016 by Daniel (talk | contribs)
But why?
Mathematics
Plocal = (Pglobal + T) * S
or equivalently:
Pglobal = Plocal / S - T
Properties
Edition
Activation parameters
Bookmarks
