Cross Section
Revision as of 12:00, 22 April 2016 by Daniel (talk | contribs) (→Procedure)
Additionally, this tool can:
  • repeat the segmentation process in one or several dimensions (to extract multiple 'slices' for instances)
  • extract polygonal contours in each slice
  • the initial clipping box is the cloud bounding-box.
  • since version 2.7, a button lets the user restore the clipping box defined on the same cloud during a previous call to this method (next to the 'reset' button, in the upper right part of the dialog).
Editing the clipping box
Interactively
Numerically
Visualization
Extract a single slice
Extract a single contour
The user must set:
  • the 'flat' dimension (it should be automatically setup based on the current section dimensions).
  • the maximum edge length: the contour is extracted thanks to a 'concave hull' algorithm. The only parameter for this tool is the 'maximum size' of a single edge (if possible). The algorithm starts from the convex hull of the slice points. As long as an edge is longer than the specified 'max length', the algorithm will try to split it by using another point in the vicinity. This way the contour will fit the cloud more tightly. So the smaller the parameter is, the tighter the contour will be. Note that this 'maximum length' can't be guaranteed as only the input points are used.
Additional options are:
  • project slice(s) points on their best fit plane: the contour extraction is done in 2D. Instead of using the slice flat dimension as projection plane, CloudCompare can project the points on their best fit plane (it can be sometimes better for very thick slices).
  • split contour(s) on longer edges: CloudCompare can split the contour every time an edge is longer than the 'maximum edge length' parameter. In this case multiple non-closed polylines can be generated instead of a single closed contour.
Extracted contour (close-up with the slice cloud)
  • you can easily 'cancel' (delete) the last generated contour by clicking on the 'revert' icon next to the button
  • to extract a non-closed contour, see the Extract Sections tool.
To extract several slices or contours at once, click on the 'Extract multiple slices' icon (in the right 'Slices' frame).
Other parameters are:
  • Repeat dimension: the extraction process can be repeated in one or multiple dimensions (by default only the 'flat' dimension will be checked)
Multiple slices (left) and contours (right) extraction
Reset the clipping box
Close the tool
