CSF (plugin)
Revision as of 10:18, 26 May 2016 by Daniel (talk | contribs) (Created page with "= Introduction = '''Airborne LiDAR Data Filtering Algorithm Based on Cloth Simulation''' Wuming Zhang, Jianbo Qi, Peng Wan, Hongtao Wang, Donghui Xi, Guangjian Yan, Xihan Mu...")
Algorithm Details
Fundamental of the cloth simulation
During cloth simulation, the cloth can be modeled as a grid that consists of particles with mass and interconnections called a Mass-Spring Model (Provot, 1995). Fig. 2 shows the structure of the grid model. A particle on the node of the grid has no size but is assigned with a constant mass.
