CSF (plugin)
Revision as of 02:21, 22 June 2016 by Peng (talk | contribs)
If you use this tool for a scientific publication, please cite the following paper: Zhang W, Qi J, Wan P, Wang H, Xie D, Wang X, Yan G. An Easy-to-Use Airborne LiDAR Data Filtering Method Based on Cloth Simulation. Remote Sensing. 2016; 8(6):501.
P.S. You can download the paper from https://www.researchgate.net/profile/Wuming_Zhang2 . You can also visit the homepage : http://ramm.bnu.edu.cn/researchers/wumingzhang/english/default_contributions.htm for more information.
Algorithm Details
Set up of parameters
General parameters
Scenes
Cloth resolution
Max iterations
Classification threshold
