Level
Revision as of 09:35, 6 October 2016 by Daniel (talk | contribs) (→Procedure)
This tool is accessible via the 'Tools > Level' menu or the icon in the left toolbar.
'Tools > Level' in action
'Tools > Level' result
  • try to pick the points as far as possible from each other to optimize the plane orientation 'accuracy'
  • you can cancel the process any time by clicking on the tool icon again
  • the first clicked point will be used as the rotation center. The vector between the first and second clicked points will be the new 'X' dimension. The third clicked point is used to determine the (XY) plane.
  • this tool modifies the selected entities directly. You may want to clone or save them prior to call this tool.
