Unroll
Revision as of 14:45, 14 January 2017 by Daniel (talk | contribs)
Cylindrical shape to unroll
Cylindrical shape unrolled
Select a cloud then start this tool.
Cylinder
File:Cc unroll dialog.jpg
'Unroll cylinder' dialog
  • radius
  • and optionally a point on the axis (otherwise CloudCompare will try to guess it by computing the cloud gravity center)
Cone
This method unrolls a cone in a way that preserves surfaces.
'Unroll cone' dialog
  • the cone apex position
Straightened cone
This method actually unrolls a cone-shaped cloud as if it was a cylinder, by first 'straightening' the cone walls.
