Unroll
Revision as of 14:56, 14 January 2017 by Daniel (talk | contribs)
Cylindrical shape to unroll
Cylindrical shape unrolled
Cylinder
'Unroll cylinder' dialog
  • cylinder radius
  • and optionally a point on the axis (otherwise CloudCompare can try to guess it by computing the gravity center of the point cloud)
Cone
This method unrolls a cone in a way that preserves surfaces (as if the cone was 'rolling' on a planar surface).
'Unroll cone' dialog
Straightened cone
