Compass (plugin)
Revision as of 17:01, 28 August 2017 by Sam (talk | contribs) (→Introduction)
ccCompass GUI showing the available modes, customizable cost functions and option for data export.
Schematic showing the least-cost path approach to trace detection in a point cloud implemented in the ccCompass plugin.
Exporting data
Further Reading and Citation
