Virtual broom (plugin)
Revision as of 11:35, 22 October 2017 by Daniel (talk | contribs) (→Introduction)
Usage
This will display the first time a disclaimer about the author of the plugin (Wesley Grimes, Collision Engineering Associates, Inc., USA). Then the plugin dedicated dialog will appear.
Position the broom
  • thickness: the thickness of the broom. This is mainly used by the plugin to stick to the surface. In the default mode (cleaning), the points falling inside the broom won't be deleted. Therefore it is good to make the broom as thin as possible. However, especially for noisy or curved surfaces, the plugin won't be able to stick the broom to the surface correctly if the broom is too thin...
  • mode: you can select
