Virtual broom (plugin)
Revision as of 12:06, 22 October 2017 by Daniel (talk | contribs) (→Usage)
Usage
Position the broom
Setup the broom dimensions
  • thickness: the thickness of the broom. This is mainly used by the plugin to stick to the surface. In the default mode (cleaning), the points falling inside the broom won't be deleted. Therefore it is good to make the broom as thin as possible. However, especially for noisy or curved surfaces, the plugin won't be able to stick the broom to the surface correctly if the broom is too thin...
Moving the broom
Manual mode
Automated mode
Undo
Delete the points
