Shortcuts
Revision as of 14:08, 22 October 2017 by Daniel (talk | contribs)
Here are listed the keyboard shortcuts (version: 2.9 and above)
Shortcut Description
Ctrl+O Open file
Ctrl+S Save selected entities
Ctrl+D Delete selected entities
Alt+C Set unique color (selected entities)
Del/Suppr Delete selected entity
Z Zoom and center view on selected entities
L Lock manual rotation around the vertical (screen) axis
B Enter bubble-view mode
A Toggle selected entities activation
V Toggle selected entities visibility (recursive)
N Toggle selected entities normals visibility (recursive)
C Toggle selected entities colors visibility (recursive)
S Toggle selected entities SF visibility (recursive)
M Toggle selected entities materials/textures visibility (recursive)
D Toggle selected entities 3D name visibility (recursive)
P Picks the rotation center (active 3D view)
double-click Sets the clicked pixel as rotation center (active 3D view)
Shift + C Toggle selected entity color ramp visibility (recursive)
Shift + Up arrow Activate previous scalar field on selected entity
Shift + Down arrow Activate next scalar field on selected entity
Shift + click on a point/triangle Spawn a 2D label on the clicked element
F1 Show help
F2 Rename selected entity (in DB tree)
F3 Toggle object-centered perspective (active 3D view)
F4 Toggle viewer-based perspective (active 3D view)
F5 Refresh display (active 3D view)
F6 Toggle sun light (active 3D view)
F7 Toggle custom light (active 3D view)
F8 Toggle Console display
F10 Toggle stereo mode
F11 Toggle full-screen mode
Ctrl+F3 New 3D view
Ctrl+F4 Close active 3D view
0 Set default "BACK" view to active 3D display
2 Set default "BOTTOM" view to active 3D display
4 Set default "LEFT SIDE" view to active 3D display
5 Set default "FRONT" view to active 3D display
6 Set default "RIGHT SIDE" view to active 3D display
8 Set default "TOP" view to active 3D display
+ Increase the zoom of the active 3D display (since version 2.6.2)
= Decrease the zoom of the active 3D display (since version 2.6.2)
CTRL + mouse wheel Change the default point size
ALT + mouse wheel Change the near clipping plane (perspective mode)
SHIFT + mouse wheel Change the field of view (perspective mode)
