Density
Revision as of 21:19, 7 December 2017 by Daniel (talk | contribs) (→Output)
A dialog will appear:
Precise or Approximate
Output
The density output can be:
Density output example
  • the central point is always used for computing the density (even when the output is the 'number of neighbors' as we consider the number of neighbors of the 'position in space' of each point). Therefore the density will be actually equal to N + 1 where N is the number of neighbors of each point)
