Interactive Segmentation Tool
Menu / icon
This tool is accessible via the icon in the main upper toolbar or the 'Edit > Segment' menu.
Polygon edition mode
- left click: create a new polygon vertex
- right after the first vertex is created, you'll see that the first polygon edge will start to "follow" the mouse cursor. You have to define the position of the second vertex (left click) in order to 'fix' it. This process will start over with the next edge and so on.
- right click: stop the polygon edition (warning: the currently 'floating' vertex won't be added to the polygon)
Rectangle edition mode
In 'Rectangle edition' mode you have to left click a first time to define the first corner of the rectangle then click a second time to define the opposite corner (alternatively you can keep the left mouse button pressed and the opposite corner will be created once you release the button).
Segmentation
Otherwise the user has to choose whether to keep points inside () or outside (
) the polygon. Once done the other points will disappear (as well as the polygon).
Paused mode
- modify the current entities orientation and segment more points (click on the
button to leave the 'paused' mode and define a new polygon/rectangle)
- reset the current selection (
- validate the current segmentation and create two clouds: one with the selected points and one with the others (
- validate the current segmentation and create only one cloud with the visible points (
) - the other points will be deleted
- cancel the segmentation process (
) (no modification will occur)
Polygon Import / Export
Import
CC will display a simple list of all polylines it founds in the DB tree so that the user can select the one he wants to use.
Warnings: - any previously defined polygon/rectangle will be discarded. - pay attention that the current projection mode (orthogonal / perspective) will change the behavior of the tool
Export
About mesh segmentation
Shortcuts
Shortcut | Description |
Space bar | Toggle 'pause' mode |
Escape key | Cancel |
Return key | Apply |
Delete key | Apply + delete hidden points |
Tab | Switch between polygon and rectangle edition mode |
CTRL key (pressed) | Use a rectangular selection area (whatever the edition mode) |
I | Select points inside |
O | Select points outside |
