Global Shift and Scale
Revision as of 12:49, 20 February 2019 by UnivSilesia (talk | contribs)
en:Globalne przesunięcie i przeskalowanie
But why?
Mathematics
Plocal = (Pglobal + T) * S
or equivalently:
Pglobal = Plocal / S - T
Properties
Edition
Activation parameters
Bookmarks
