SBF
Revision as of 11:47, 9 February 2020 by Daniel (talk | contribs) (Created page with "=Introduction= The SBF (Simple Binary File) format, is meant to ease the export and external processing of big point clouds. While the BIN format of CloudCompare can store a...")
While the BIN format of CloudCompare can store about anything created or loaded in CloudCompare, it is complex to decode (as it is a serialized stream of what is loaded in the memory - the only way to properly open a BIN file is to use QCC_DB_LIB).
Thus, the SBF format has been created to store data in a Binary file with a very simple structure, and to store some more meta-data in a text file next to the binary file.
Specifications
Binary file
Total length: 64 bytes
0-1 SBF header flag 42 42
36-63 Reserved for later 0
Body
All values are saved with 32bit floating point precision (= 'float').
For each point (1-Np):
