SBF
Revision as of 17:26, 9 February 2020 by Daniel (talk | contribs) (→Ascii file)
Specifications
Ascii file
[SBF]
Points=362315
SFCount=10
SF10=name of scalar field{, p=precision, s=shift value}
Binary file
Total length: 64 bytes
0-1 SBF header flag 42 42
36-63 Reserved for later 0
Body
For each point (1-Np):
