Compute geometric features
- Roughness (equivalent to the former Roughness tool of v2.9 and below - in version 2.12, an option allows to compute signed roughness values)
- Curvature (equivalent to the former Curvature tool of v2.9 and below)
- Mean curvature
- Gaussian curvature
- Normal change rate
- Density (equivalent to the former Density tool of v2.9 and below)
- Number of neighbors
- Surface density
- Volume density
- Moment
- 1st order moment
- Features
- Sum of eigenvalues
- Omnivariance
- Eigenentropy
- Anisotropy
- Planarity
- Linearity
- PCA 1
- PCA 2
- PCA 3
- Surface variation
- Sphericity
- Verticality
- 1st eigenvalue
- 2nd eigenvalue
- 3rd eigenvalue
- most of the above features are defined in "Contour detection in unstructured 3D point clouds", Hackel et al, 2016
- curvature formulas computed from a local quadric function come from: "Three-dimensional surface curvature estimation using quadric surface patches", I. Douros and B. Buxton, University College London
- roughness computation algorithm is described in the old Roughness tool description page
A dialog will appear:
Notes: - currently each feature is computed independently. The extraction of the local neighborhood is sadly not leveraged for all the features... - since version 2.12, an option allows to define a 'up direction' to compute signed roughness values
Output
