Rasterize
Revision as of 14:12, 19 February 2022 by Daniel (talk | contribs) (→Grid position)
Input cloud
Generating a raster grid
'Rasterize' tool dialog
    • minimum height of all points falling in this cell
    • average height of all points falling in this cell
    • maximum height of all points falling in this cell
Empty cells
  • interpolate (see below)
Interpolating empty cells
Interpolation principle
Grid position
Grid extents setup dialog
Raster grid
Interpolate scalar fields
Resample input cloud
Export
Cloud
Raster
ASCII matrix
Contour plot generation
The user must specify:
Since version 2.6.2
Hillshade
  • click on generate
