Roughness
Revision as of 21:55, 19 February 2022 by Daniel (talk | contribs) (→Menu)
This tool is accessible via the 'Tools > Other > Roughness' menu.
This tool estimates the 'roughness' of a cloud.
CloudCompare will only ask for the 'kernel size': the radius of a sphere centered on each point (see the Notes below).
Roughness output
  • Roughness estimation is very... simple: for each point, the 'roughness' value is equal to the distance between this point and the best fitting plane computed on its nearest neighbors.
  • If there's not enough neighbors to compute a LS plane (i.e. less than 3) an invalid scalar value (NaN) is set for this point. This point will appear in grey (or not at all if you uncheck the 'display NaN values in grey' option in the scalar field properties).
