Cross Section
Revision as of 21:04, 31 March 2022 by Daniel (talk | contribs)
Additionally, this tool can:
Editing the clipping box
Interactively
Numerically
Visualization
Extract a single slice
Extract a single envelope
  • set the maximum edge length: the envelope is extracted thanks to a 'concave hull' extraction algorithm. The only parameter for this tool is the 'maximum size' of a single generated edge. The algorithm starts from the convex hull of the whole set of points. As long as an edge is longer than the specified 'max length', the algorithm will try to split it by using another point in the vicinity (if possible). This way, the contour will fit the cloud more tightly. So the smaller this parameter is, the tighter the contour will be. Note that this 'maximum edge length' can't be guaranteed as only the input points are used.
Additional options are:
  • split envelope(s) on longer edges: CloudCompare can split the envelope every time an edge is longer than the 'maximum edge length' parameter. In this case, multiple non-closed polylines can be generated instead of a single closed contour.
Extracted contour (close-up with the slice cloud)
Extract a single contour
Extract several slices, envelopes or contours
To extract several slices, contours or envelopes at once, click on the 'Extract multiple slices' icon (in the right 'Slices' frame).
Other parameters are:
Multiple slices (left) and contours (right) extraction
Reset the clipping box
Close the tool
